View Full Version : I need help figuring out this gas leak.
aggressive male
06-27-2008, 11:51 AM
I have a cadillac with throttle body injection and the fuel pump mounted to the frame. I noticed that while it was running fuel was dribbling down the gas tank but when I shut it off it would stop dribbling. I figured it must be a leaky fuel return line. So I disconnected the fuel line at the engine so that I could run the fuel pump to drain most of the gas into gas cans. I figured I might deform the tank taking it off while it's almost full. So now that I have the tank off but still attached to the gas lines I turn on the fuel pump to see where it was leaking. I can hear the fuel going through the lines pouring into the tank but it's not leaking now. How could this be?
paul67
06-28-2008, 01:10 PM
lack of back pressure as its not feeding the injectors maybe ?
Chevy
07-01-2008, 10:07 AM
Maybe the leak isn't in the fuel return line but in the tank--and now that the tank is no longer full you don't see the leak because it's high up on the tank?
good luck at any rate.
aggressive male
07-06-2008, 01:15 PM
Thanks for the replies guys! I think I found the problem but not sure. I took out the fuel sending unit and that O-ring that goes between the tank and the sending unit was partially out and hanging in the hole. So if I slammed on the brakes I guess it was leaking out, I didn't have anyone look so I don't know. I think if I remember right I had a hard time getting that O-ring in last time because it was slightly too small but it seems to be stretched out correct size this time. Is it possible I could have used some octane booster or fuel system cleaner that changes the size of rubber parts like that? Thanks
paul67
07-07-2008, 01:52 AM
If I were you I would buy a new 1 as it's probaly lost its integrety remember the shuttle.
