View Full Version : 4th gen m/c & booster on my 69' Firebird??
69TA
06-26-2008, 08:08 PM
My LT1/4L60e 69' Firebird currently has factory 4wheel drum manual brakes. I just ordered a front disc brake setup for it.(disc spindles, rotors, calibers etc..) Check it out here: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&sspagename=ADME%3AB%3AEOIBSAA%3AUS%3A11&viewitem=&item=190230909451
I have a 94' Firebird Formula parts car(where I got the LT1/4L60e from). I am planning on using the master cylinder/booster, and rear disc brakes from this car on my 69' Firebird.
I know Ill have to cut the firewall a little to mount the booster as well as use 2 RH side rear caliber brackets due to my staggered shocks. But has anyone done a conversion like this? Will it work and/or do I need anything else for the install? Ive done alot of searching on here for an answer but cant find any good info...
SatisTraction
06-26-2008, 08:33 PM
you do not have to cut the firewall. I modifed the booster to fit the 1st gen pedals.
69TA
06-26-2008, 08:53 PM
Well thats good news.. I figured I had to from seeing this: https://www.pro-touring.com/forum/showthread.php?t=37217&highlight=ls1+booster
Can you elaborate on that? Do you have any pics? Im sure Ill figure it out when I start installing it, but what exactly did you do? Is the booster in the way of your steering column?
SatisTraction
06-27-2008, 02:13 AM
no the booster fit nice with the ls1 and stock wiper. i knocked the studs out of the booster, lined the booster up and drileld the holes. I had to extend the lower part of the booster mount.
SatisTraction
06-27-2008, 02:15 AM
https://www.pro-touring.com/forum/showthread.php?t=36279&page=2
69TA
06-27-2008, 08:37 AM
Ahh that makes sense. Im going to fab it up and install it as soon as my disc brake kit gets here. Thanks for the help!!
