View Full Version : Simple Question* LS1 68 Camaro
68rsss
06-26-2008, 03:45 PM
I have this thread in the electrical section also.
My harness said nothing about the altenator wire so I connected it directly to the battery.
The other day the altenator was generating 17vdc and now it's dead and doesnt charge.
I just wanted to check and be be sure that on the LS1 altenator the little red wire should be connected to the battery directly, correct?
Thanks in advance,
Jer
dhutton
06-26-2008, 04:17 PM
There is a lot of information on this topic on ls1tech.com in the conversions forum. Here is a start:
http://www.ls1tech.com/forums/showthread.php?t=779728
Don
CarlC
06-26-2008, 09:02 PM
On my 2002 LS1 Camaro harness/alt/ECM there is only one red wire and it is attached to the ECM. The ECM controls the alternator function. The main charging wire does go to the + bat.
68rsss
06-27-2008, 05:50 PM
Thanks Guys, i have access thru a mech freind of mine to a website called alldatapro.com. I found the same info this afternoon after I bought a new altenator and had the same results.
68rsss
06-28-2008, 01:50 PM
This worked! Thanks guys.
