    Results 1 to 10 of 10
      67 Camaro wheel size with mini tub
      67 Camaro, Using DSE Mini tubs, leaving axle stock width. What size wheel tire/combo? I'd love to fit some 335s on it if I could.
      nevermind saw that they did an 11" with 335 on velocity
      Jun 2008
      San Antonio
      Check this out. Its on 335s
      Jun 2008
      San Antonio
      Camera phone pic
      Jul 2007
      Los Angeles, CA
      That is such an awesome stance and set of wheels and tires on that car.
      wheel size?
      Arlington Heights, IL
      How about some more pics of that Camaro!!!
      1969 Camaro under construction.
      1967 firebird. 6.0/t56. Ridetech stage 2. Moser 9 inch. Forgeline wheels.(SOLD)
      North Bend, WA
      My 67 has DSE tubs and stock width 12 bolt. Without rolling the rear quarters, the max wheel lip was 3" (leaving 1/2" outer gap) and 9" max backspace (leaving 3/4" inner gap). In order to get 335's on mine, I'd have to roll the lips, and it wouldn't leave much space on either side. Using 335's would require a very stiff rear to not rub around hard corners, especially if the car is lowered.
      In my case, since wheels wider than 10" start gouging the budget, I'll be buying 10" wheels. Tires will probably 285mm (11.2"), so the rubber will stick out .6" more than the rim. Much more than .6" and I'm guessing the tire sidewall behavior will suffer around turns.
      My advice would be:
      1) Measure yours since your rotors and amount you lower the car might cause a significant difference, and
      2) Remember the body will move around hard corners. Leave some gaps on both sides to allow this. How much to leave depends on how stiff your car is after modifications.
      Jun 2008
      San Antonio
      [quote=CamaroJesse]How about some more pics of that Camaro!!![
      /quote]
      Jul 2007
      Los Angeles, CA
      Quote Originally Posted by Turbo67camaro
      I have found usually you can go up to 11", usually the 12" wide rims really start bumping up the prices. It probably also depends on the rim manufacturer and size.
