View Full Version : 98-02 Blazer spindle question
twfurst
06-21-2008, 09:37 AM
I am getting ready to purchase a set of 98-02 Blazer spindles with the sealed hubs to run on my 87 Monte Carlo SS. I am wondering if anyone has any information on getting or making a bracket to mount the calipers and 12" rotors from a 2002 Z28. I have seen a lot guys mounting 13" C5 rotors, but my Torq Thrust IIs won't allow it from what I've been told. Hope someone can help.
Samckitt
06-21-2008, 11:38 AM
What dia wheels you running? 16"?
jerome
06-21-2008, 08:45 PM
If you do decide to go with C5 brakes, I would seriously look at all the costs of a blazer spindle and brake brackets vs. an ATS spindle. Keep in mind you get better geometry and a better hub with the ATS spindle. If you're coming up with similar costs, do the ATS spindle.
If you do the blazer brakes, then I guess you do save quite a bit.
Jerome
Samckitt
06-22-2008, 05:08 AM
I got mine for $100 for the pair, with hubs. Compared to over $600 for the ATS ones.
NvrDun71
06-22-2008, 09:17 AM
Not to hijack the thread, but I've got a set of stock like new spindles off of my 02' GMC Sonoma I would let go for cheap... Let me know if your interested
Samckitt
06-22-2008, 10:50 AM
02 Sonoma spindels are different than 98-02 2WD Blazer spindles.
NvrDun71
06-22-2008, 11:10 AM
damn didn't realize that...learned somethin new. What are the differences?
Samckitt
06-22-2008, 11:19 AM
I'll look for pics, but the 98-02 "Spindles" use a hub with bearings, a slip on rotor & 2 piston calipers.
Samckitt
06-22-2008, 11:38 AM
Can't find any good pics on the net, I'll take some pics of mine later.
Bad94
06-22-2008, 02:29 PM
I would do a 2100 belltech spindle and LS1 rotors and C5 cailpers.
Im doing S-10 big brake kits, and i have brackets for that.
And that set up will fit in a 17" Eagle 211(they look just like TT 2's) Not sure if they fit 17" american racing TT 2's.
Samckitt
06-22-2008, 04:08 PM
I have the same setup except using C5 calipers, "sadle" brackets & rotors. I felt they fit better than the LS1 ones did. But now I don't remember why.
Samckitt
06-22-2008, 04:30 PM
My brake setup using C5 Vette calipers & rotors on 98-02 S10 Blazer spindles:
https://static1.pt-content.com/images/pt/2008/06/IMG_3182-1.jpg
https://static1.pt-content.com/images/pt/2008/06/IMG_3181-1.jpg
https://static1.pt-content.com/images/pt/2008/06/IMG_3180-1.jpg
https://static1.pt-content.com/images/pt/2008/06/IMG_3179-1.jpg
https://static1.pt-content.com/images/pt/2008/06/IMG_3178-1.jpg
Memphis
06-22-2008, 04:43 PM
Are those just stock spindles or did you have to drill anything?
Samckitt
06-22-2008, 05:00 PM
Stock spindles. Only thing I did was hit it with a grinder just a "tad" in picture 4 & 5. Pic 4 is on the lower left side where the adapter bracket interferes with it, & in pic 5 where the black bolt needed a little clearance.
twfurst
06-22-2008, 06:16 PM
I'm running 17" Torq Thrusts. They were purchased when I it was still running all stock components, so it has the stock backspace. I have a brand new set of calipers for a 2000 Z28 SS. I've been told that these are the same as the C5, only they don't say "CORVETTE" on them.
twfurst
06-22-2008, 06:23 PM
https://static1.pt-content.com/images/pt/2008/06/IMG_3178-1.jpg Did you make the bracket in these pics? If so, do you have a drawing with the dimensions? Thats exactly what I've been looking for.
Memphis
06-22-2008, 06:55 PM
Are the C5 Z06 calipers different than the regular C5's?
Samckitt
06-22-2008, 08:21 PM
Yes. I have been trying to find my CAD files and/or drawings of the brackets. But am not having any luck.
I don't know. These are almost 13" dia & 1.25" thick.
RudeJester.s10
06-23-2008, 06:20 AM
Are these brackets readily available from you?
Samckitt
06-23-2008, 07:22 AM
Not at the moment, but if I can find my drawing for them, or redesign them, I can (should) have some made.
twfurst
06-23-2008, 09:30 AM
Is that an AutoCad Drawing? If it is, what version? I have 2006.
Samckitt
06-23-2008, 10:21 AM
Mine is a Unigraphics NX file.
jerome
06-23-2008, 07:33 PM
c5 zo6 is red, c5 regular is gray/black...i think those are the only differences
twfurst
06-24-2008, 03:16 AM
I may be able to view that at work. We have a few different programs for viewing blueprint/design type files
Samckitt
06-24-2008, 06:51 AM
My prior post:
twfurst
06-24-2008, 07:43 AM
Sorry about that. I thought you were indicating you had located them. Would that same bracket work for the 12" Camaro rotors and caliper? I'm not sure if the saddle is different between the C5 and Camaro. If it isn't, at least now I have an idea of where to start. How thick is the bracket, looks to me about 1/2".
Samckitt
06-24-2008, 07:50 AM
The "LS1" Camaro saddle bracket is different than the C5 one. With the Camaro one the adapter bracket has to be put on the other side of the Blazer spindle & long spacers are needed between it & the saddle bracket.
I started with 1/2" & had a "tad" machined off.
twfurst
06-24-2008, 08:59 AM
Is that a steel bracket, or aluminum?
Samckitt
06-24-2008, 09:16 AM
Steel
twfurst
06-24-2008, 10:10 AM
Did you have to change the wheel studs at all? I wouldn't think so, considering that the hubs had slip on rotors to begin with.
Samckitt
06-24-2008, 11:29 AM
I did. For 2 reasons. 1 - safety because the existing ones didn't protrude past the lug nuts, without spacers. And 2 - with a 3/16 spacer (because wheel barely rubbed the caliper) made reason 1 even worse.
twfurst
06-25-2008, 03:31 AM
What length did you end up going with? Did you get them at the local parts store, or order them from someplace like Jegs or Summit? Sorry to be asking so many questions, I'm just trying to be as prepared as possible.
Samckitt
06-25-2008, 05:23 AM
I bought them from Summit, they are made by Moser, P/N: MSR-8255. They are 12mm x 2.5" - .505" knurl
wheelz
07-01-2008, 12:37 PM
I have the bracket kit available to mount the C5 13", C5 13.5" Z51, or the C6 14" Z06 brakes onto the Blazer(ZQ8) spindle.
kit includes:
2 brackets
4 bolts to mount bracket to spindle
4 bolts to mount caliper abutment to bracket
2 shims to replace the dust shields
loctite
the older style aluminum bracket is still available, the C6 14" Z06 brakes will not fit this bracket. A new design steel bracket is now being supplied with the kit, all C5/C6 brakes will fit this new steel bracket.
http://www.cardomain.com/id/lt4xtremes10 main page
http://www.cardomain.com/ride/673502/2 ZQ8 setup
http://www.cardomain.com/ride/2362447 mounted on Monte SS
http://www.cardomain.com/ride/688778/4 more brake pics
Jason Hurst
RPM Automotive
6411 Pike St
Mineral Wells WV 26150
(304)482-1300
[email protected]
ps. sorry mods if this is not the proper place to post this please let me know.
Samckitt
07-01-2008, 12:56 PM
Jason,
Will you sell parts separately? I would like the dust shield shims.
wheelz
07-07-2008, 07:25 AM
Yeah I'll sell the parts separately.
Scott Pm sent
fabhammer
07-12-2008, 08:32 PM
from my experience the only difference between camaro ls1 front calipers is cooling fins and corvette on them .bolt spacing, hole placement is the same .if you use a c5-6 conversion bracket caliper will be 1/2 inch to far out for12 inch ls1 camaro rotors. i found this when i started building my own brackets for 1st gen camaro spindles using a pattern i got off the web had to pull holes in 1/2 inch so pads didnot hang off rotors 13 inch vette rotors wont work with 16 inch wheels
