View Full Version : baer tie -rod ends
$Mike70Z-28
06-16-2008, 07:05 AM
what do you gays think of the baer tie rod ends
gearheads78
06-16-2008, 08:20 AM
They are just ABSOLUTLY FABULOUS !!! :poke: :razz:
Shawn MacAnanny
06-16-2008, 04:19 PM
lmfao
Marcus SC&C
06-17-2008, 02:17 PM
:lol: :lmao: :eek: :rotfl: Oh man, I needed that!
Heh,back to the tech. Strictly speaking they aren`t tie rod ends, they`re heims. They`re fine for adjusting bumpsteer or occasional use cars but don`t expect them to last like real greasable tie rod ends. You can have the best of both worlds with our modular tie rod ends. http://www.scandc.com/balljoints.htm They`re sealed and greasable but can be had either with different height studs or with a 5/8" threaded stud and jam nut. The tall stud versions don`t require any mods except maybe longer tie rod sleeves. The threaded ones require drilling and tapping the steering arms but they`re the top choice for quick and easy bumpsteer adjustment with just 2 wrenches and no disassembly. Mark SC&C
$Mike70Z-28
06-23-2008, 11:22 AM
its for a 70 camaro not 69
Marcus SC&C
06-25-2008, 01:17 PM
I saw your screen name but you didn`t specify. A lot of guys on here have several cars or a screen name for a car they sold years ago. The `70 bumpsteer curve it pretty darn good already you shouldn`t need to change anything unless you run extreme + caster and the changes will be fairly small. The threaded stud tie rods would be a better choice anyway and they will work on a `70 (or darn near anything else) . I`d suggest checking the bumpsteer before you spend money on bumpsteer adj. tie rod ends. Mark SC&C
$Mike70Z-28
06-26-2008, 07:25 PM
thanks marcus
