derekf
06-16-2008, 05:35 AM
Installed most of the front suspension in the El Camino this weekend. Lower control arms are stock GM with steel bushings. Driver's side went in without much difficulty and moves somewhat easily (bushings aren't yet lubed).
Passenger side is a bit more difficult. After I put the first bolt in, the other bushing was off by ~ 1/2". (to be specific, I put the rear bolt through first, and the front bushing was outboard by about that distance).
I'd had some frame work done to the car years ago, the frame had torn free at the rear mount on that side:
https://static1.pt-content.com/images/pt/2008/06/frame1-1.jpg
I got the repairs done by a shop here in Dallas that was highly recommended by the local Camaro club - Advantage Autoworks, so I have to assume they did a good job; I certainly didn't have any problems with it until now (although their weld is a bit on the ugly side):
https://static1.pt-content.com/images/pt/2008/06/08061558-1.jpg
(sorry about the pic size, I can't fix until I get home, no access to photo hosting sites from work)
The arm does move, but with quite a bit more effort than the other side.
I'm guessing that they didn't quite get things lined up right with the rubber bushings, even though they were relatively new.
How worried do I need to be? I'd guess that either something will bend to get lined up better, or the mount will tear free again (and at that point could be rewelded in a better spot) - or is this a case of drop-everything-and-send-it-to-a-frame-shop-NOW? Is there a chance that the problem is the LCA and not the frame (it doesn't look bent)
