DCx
06-12-2008, 03:04 AM
im running a 750 mechanical secondary mighty demon on my carbed ls1. when i first start the car it idles at around 900-950 but after a quick drive around the block it will idle at 1100 rpm. what is the major cause for this?
the carb is out of the box stock. i literally took the carb off my old 355 and threw it atop my ls1 and ran it as is. i checked the gap between my accelerator pump linkage with a .0012 feeler gauge, that checked out. i have two large springs pulling the linkage shut (sometimes wonder if the springs have too much tension) and im running a home made heim joint throttle linkage with aluminum holley bushings like these at the carb linkage and at the throttle pedal arm.
https://static1.pt-content.com/images/pt/2008/06/6a2c_1_bJPG-1.jpg
i noticed my flots are a tad low, about 1/4 of the way in both the front and back. i didnt recheck the transfer slots before installing the carb, but it ran great on my old small block. the idle screws are about 1/2 turn out if my memory serves me. the idle is a tad rich but the car has no stumble. i have the idle ease screw but it never changes anything when i mess with it.
my cam is rather large and only pulls 10" of vacuum when the gauge is hooked up to the carb.
Texas Speed Magic Stick 3 cam - 237/242 .603/.609 113LSA
i programmed my ignition to run 17* timing from 0-1000 rpm and slowly ramp it up to 29* total at 3000 rpm.
also my fuel pressure is at 6-6.5 psi constantly.
i can press on the linkage with my hand and the idle will lower as long as i put some force on it.
and lastly. here is a pic of my home made linkage. the throttle arm sits way low compared to the height of the ls1 intake. so i bent up some threaded rod. the Z shape needs to be revised. its actually too long and i cant achieve full throttle at the moment. i was thinking of making my new linkage a lazy L shape.
https://static1.pt-content.com/images/pt/2008/06/throttlelinkage1-1.jpg
https://static1.pt-content.com/images/pt/2008/06/throttlelinkage2-1.jpg
should i run this return spring bracket instead? (my old linkage is pictured. too bad it was way too short to make it to the throttle arm).
https://static1.pt-content.com/images/pt/2008/01/throttlespringbracket-1.jpg
