whytry
06-10-2008, 07:40 AM
I have been trying to figure out which way to go for a couple weeks now, and over the weekend my current m/c went out and I only had rear brakes... Luckily I was close to home. I will be running a manual setup, eventually 4 wheel disc, right now looking to upgrade just front's. I have the 18" Budnik Fat Lip Fontana's all around.
I have been looking at three setups, and all are board sponsors, if I recall. They are:
Touring Classics - Hybrid kit, 13" rotors C5 Caliper Drilled and Slotted, comes with new master cylinder, but I will need to find some drum spindles and hubs for their setup to work. They use a 2 piston caliper, and the added bling of 13" rotors
CPP - Seems to be a pretty good kit all around but I like the C5 Caliper better than the truck caliper they use on their kit, plus will need to get a new M/C - not a big issue, already know which one to use. 2 piston caliper. Can use my existing spindles.
Kore3 - True C5 setup, with C5 calipers, and C5 rotors, drilled and slotted. Also will need new m/c but again I know which one to get. 2 piston caliper Can use Disc Spindles and comes with new hubs.
If I have any of this wrong, then I need to rethink the setups, but from what I can tell they are all in the same price range of somewhere between $800-1000 total.
The car will be driven hard, but not an all out autocross warrior or track car. Mainly street use but still driven hard.... Since my car is now just sitting, I am hoping to get something ordered in the next week...
I'm not that familiar with Wilwood's stuff, so I am open to suggestions there as well.... Frank?
Any input would be appreciated.... I know I am not a brake guru...
