View Full Version : Signs your project needs some work.
mach1stang
06-04-2008, 05:52 PM
Ok here is somthing we all can relate to in some way or another, these don't true. What are some sure fire signs that your project may need some work.
Like if you decide to use a DA sander to strip your car because your scared of what may be blown away, and half the quarter panel falls off before you hit metal... your project may need alittle work.
If you check the VIN numbers on your mustang, and it comes up as a 88 chevy pick up your project may need some work.
lets see what you guys can up with.
CRCRFT78
06-04-2008, 05:58 PM
You keep buying other cars to enjoy because your project isn't finished. STOP buying other cars and GET TO WORK.
Restomod
06-04-2008, 06:13 PM
You cant find it in the shop cause of all the stuff piled on top of and around it!!!
CHRIS67
06-05-2008, 03:27 AM
When I still have money in the bank.
ho428
06-05-2008, 04:16 AM
When your wife tells you to go work on it.
Posi12Bolt
06-05-2008, 05:57 AM
when you have to mow the lawn to FIND your project... You need to get to work!
mach1stang
06-05-2008, 08:41 AM
When your sports roof stang is a convertible... your project may need some work.
BlownBigBlock
06-05-2008, 09:00 AM
You buy enough spare parts to build another car, build the car then realize the original project that you bought is still sitting then unfiinished.
parsonsj
06-05-2008, 09:31 AM
When you buddies refer to your paint job as "primer", as in "that blue primer could really mess up the color".
jp
69Pony
06-05-2008, 11:47 AM
When you buy a brake booster, then a vacuum pump and then a Hydraboost and still haven't installed any of them.
Or when you forget what you originally had planned for the project.
Damn True
06-05-2008, 12:36 PM
When you go to the DMV to pay your non-op registration and the mouth-breather behind the counter says "You're still not done with that car?"
ho428
06-05-2008, 12:59 PM
You buy enough spare parts to build another car, build the car then realize the original project that you bought is still sitting there unfiinished.
I resemble that remark.
Patrick
06-05-2008, 05:19 PM
Been there....Done that....on more than occasion.
I have friends that have built nearly complete cars off the stuff I have "redone".
redfire69
06-06-2008, 09:55 AM
X2... and she says "maybe you should have considered the dynacorn body"... true story :doh:
trapin
06-06-2008, 11:07 AM
If you live in a house that is mobil and have 5 cars in the front yard that aren't.......you might be a redneck.
Oh wait....that's a different joke.
megaladon6
06-07-2008, 04:37 PM
when you start the project and your youngest brother is still in high school, then when he's 28 he starts his own project and has it done first.
