funbnme
06-04-2008, 05:28 PM
Having cooling issues with my 68 Camaro.
Here's the specs of my motor:
400 sbc .40 over...so a 408
400 crank & rods.
10/1 compression pistons...Keith Black ( I can add the part numbers tomorrow)
New street cam...not sure of specs, but it's not an aggressive race cam
Iron heads are good...no issues with them. I don't know the casting number, but was told they are 69 performance heads with good valves. Just had a valve job too. They are setup right for the 400 block. The builder does a lot of 400's, so he knows the motor and parts that work with it.
I know the 400's have the simese cylinders. My motor is setup to put out about 400hp to the wheels.
Now runs on 93 octane fuel.
current cooling system:
4 row radiator...not new, but clean. Doesn't look gummed up inside. Engine builder checked it out.
160 thermostat installed...brand new
15lb radiator cap
Electric Fan...but mounted to a shroud that's blocking airflow. It's basically an alum. plate that the fan mounts too, but there's no spacer between the alum & the radiator, so the only place the air flows through is where the fan is. Engine builder says it needs to go.
The shop that built the car uses this setup on all of the cars they build, but I don't think they've used a 400 block.
I have the Vintage Air setup. Coils mount in front of the radiator.
Tonights issue:
Just picked up the car from the engine builder. He was tuning up the motor before I took it home. Set timing, dist curve, carb jets...everything you need to do. The motor was completely rebuilt because the previous config required race fuel and was not streetable -- 12.8/1 compression pistons were in it.
Motor has 5 miles on it now.
Driving home tonight, the car got into the 220 range and keeps climbing after about 5 miles in traffic. That's from a cold start and without the a/c running.
I pulled over as soon as I could and let it cool down to about 140 on the gauge. That was about 40 mins on the side of the road.
I took off again and it got hot within a couple miles. Wound up pulling into a Shoneys ( of all places to have dinner ) and getting it trailered back to the shop that built the car...different than the motor guy.
Question:
For anyone here running a 400sbc with Vintage Air, what's your cooling system setup?
Can I run an alum. shroud that has space for airflow to go through the whole radiator and keep the electric fan? Will it flow enough air?
I didn't even have the a/c running...will this thing be able to keep cool with the a/c on? I live in South FL and it's hot down here...a/c is required for me.
I'd like to have part numbers and specifics on your setup so I can review everything with the shop & the engine builder before any changes are attempted.
Thank you for the help. If you have ideas or more questions...or want to talk me off the ledge...PM me your number & I'll call you during the day.
400 crank & rods.
15lb radiator cap
Tonights issue:
Question:
