View Full Version : Holley Electric Fuel Pump Making Weird Noise
bigboi
06-03-2008, 08:34 PM
I have a Holley HP150 Fuel Pump. It's running to an Aeromotive Regulator and then to a Holley 750 Carb.
Sometimes the fuel pump sounds normal when it's running and then sometimes it makes a weird sound like it's having a hard time pumping the fuel... It sounds like "waaah waaaahhhh waaaahhh waaahhh".
Anyone experience this or know why it's doing this? Sure doesn't sound right to me.
Bobby Schulz
06-04-2008, 06:04 AM
Are you running a dead head reg?
I have seen them if they run for a bit the pump/fuel will heat up and even bog down when used without a bypass style reg.
Also I suggest running a larger inlet line to the pump than the outlet side so that it wont cavitate the pump.
I run a -12 line/filter to the Aeromotive A1000 pump and then a -10 line/filter to a bypass style reg. with dual -6 line to the 1195 king demon dominator:attn: :woot: :hail:
bigboi
06-04-2008, 07:21 AM
It's a non return reg. Is this noise/problem bad for the pump? It sounds like hell.
I called Holley and they said to return the fuel pump so I have summitracing sending me a new pump. I'm wondering now... Maybe the next pump will do the same thing. :banghead:
Here is what I am running...
-10 from tank -> filter -> fuel pump inlet.
-8 from fuel pump outlet -> OEM hard line -> -10 to reg -> -6 -> 750 carb
1195 king demon - LOL! Got' Damn - What size motor you running?
Bobby Schulz
06-04-2008, 10:37 AM
Hehehe. engine size is a 598 tall deck;) 4.600 bore x 4.500 stroke:jawdrop:
I ran the holley blue,and then black pumps and they seemed to die after about 6months to 1 year of of street driving on my old 468 I had with a non return style. I had better luck with a return style and so have most of my friends.
bigboi
06-04-2008, 11:09 AM
598... Whew... Maybe when I blow this one apart I can get something like that... LOL!
Hmm... The HP150 pump doesn't have a return... :\
Bobby Schulz
06-04-2008, 12:20 PM
Use any pump you like just get a reg with a return and run a extra fuel line from the return style reg to the tank.:drive:
bigboi
06-04-2008, 05:27 PM
Hmmm... How can I tap the tank with a fitting? I think some of the later model Camaro fuel sending units have a return fitting. I just gotta figure out which one fits the 67 tank and buy one of those.
:bananna2:
Bobby Schulz
06-05-2008, 05:30 AM
You could drop the tank and have a shop install a fitting. (unless you know how to weld gas tanks dont try it...gas vapor can ignite even with the tank drained).
Or do a bulkhead like some fuel cells have.
bigboi
06-05-2008, 08:38 AM
Bulkhead looks like the easiest method. Thanks.
What regulator are you using? I like the Aeromotive regs but all the bypass regs they make have a 1:1 boost reference port on them. I am assuming this port is for turbo applications??
To run braided line all the way back to the tank that's gonna throw another $170 in the mix... Geeeeeeeeesh....
:nopity:
Bobby Schulz
06-05-2008, 10:33 AM
I forget the model number on my reg but its red/black that looks kinda like a egg:rolleyes: and it also has the bost reference. But for now its blocked at least untill the procharger:6gears:
You could always run pushlock hose from the reg on back. Little cheaper.
bigboi
06-05-2008, 03:56 PM
If I run -10 to the reg should I just run -10 back to the tank?
Bobby Schulz
06-06-2008, 04:46 AM
The return dosent have to be as big but I would use -8 or -10.
bigboi
06-07-2008, 10:19 AM
Well I found some brass fittings that I am going to use as a bulkhead. I am going to drill a hole in the sending unit and run pushlock hose along the frame. I will connect the pushlock hose to braided hose so in the engine compartment it looks nice. :headbang:
I also found the Aeromotive Reg I am going to use. Looks kinda like an egg (how you were describing).
Should work out ok!
