View Full Version : Wayne Due C4 Front Suspension Question
FrankenChevy
06-02-2008, 10:05 AM
I have a Wayne Due C4 front clip in a '67 Camaro and it has two sizes (lengths) of spacers to mount the upper control arms to the frame. I've looked at pics on this site and others and now I'm totally confused on whether the long spacer goes in the front bolt or back bolt. Anyone know? I'm sure spacers/washers will need to be added but I need a starting point. Thanks.
JSR69
06-04-2008, 03:05 PM
Mine has the same size spacer front and rear. However, I haven't had it aligned yet, so that may change.
ProdigyCustoms
06-04-2008, 03:35 PM
Thick on the rear for more caster with less shims
beyonda68
06-08-2023, 04:32 PM
Do you know what kind of sway bar you ran with this clip.
marolf101x
06-08-2023, 05:55 PM
https://1speedway.com/index.php?route=product/product&path=76&product_id=90
Mbaroza12
01-23-2026, 10:35 AM
How’s it going guys I know this is an old post but figured it’s worth a shot. What’s everyone with Wayne due front and rear running for alignments specs?
dhutton
01-23-2026, 04:01 PM
I would just use David Pozzi’s alignment specs for the front.
https://pozziracing.com/first_gen_suspension.htm
