View Full Version : HEGO and 6A mounting location - Trans TunnelOK?
thedugan
06-01-2008, 04:30 AM
I'm trying to find a good spot to hide the 2 boxes (HEGO and 6A).
I mocked them up where they would mount to the high side of the transmission in the trans tunnel. Its up and out of the way, would be away from any heat.
I really dont want to go thru trying to mount them inside the car, and inside the engine compartment shows to many wires.
I can shoot some pictures if you need a better visual.
__________________
MonzaRacer
06-01-2008, 05:25 PM
no need to have HEGO inside car, MSD is sealed but should be up away from heat(ie trans like inside fender on wheel well.
ProdigyCustoms
06-01-2008, 05:34 PM
I would NOT put the 6A in the car. Too much noise in the elctronics. Noise in your stereo. Hide that under the fender well. I put the ECM and HEGO on the firewall behind the Gen IV, then did (2) holes through the top of the tunnel at the firewall. Then snake the Hego down to the O2, and the main harness up behind the engine.
