View Full Version : turbo 400 will it fit?
Redneckpsd
05-29-2008, 11:51 AM
I just came across a fresh turbo 400 from a 1985 gmc with the 6.2L diesel. Will the tranny bolt up to a 454?
MarkB
05-30-2008, 04:08 PM
Yes the transmission will bolt up to your 454. It may have a very low stall converter, coming out of a diesel, but it will bolt up.
Mark
Bowler Performance Transmissions
Redneckpsd
05-30-2008, 09:33 PM
Mark thanks for the info. I thought it would bolt up just wanted some reassurance. I plan on changing the torque converter.
HILROD
05-31-2008, 05:29 AM
The valve body is also different. Diesels shift at 2000 rpm, or less generaly. This will cause trouble, more so if you have a performance application.
Gtrpunk23
06-01-2008, 10:33 AM
I just came across a fresh turbo 400 from a 1985 gmc with the 6.2L diesel. Will the tranny bolt up to a 454? Yes it will
Gtrpunk23
06-01-2008, 10:42 AM
I just came across a fresh turbo 400 from a 1985 gmc with the 6.2L diesel. Will the tranny bolt up to a 454?Also if you need a convertor give me a call 201-489-7770. I can have any stall, for any horsepower made by my convertor supplier. I own European Exchange Transmissions (europeanexchange.com) and been at it for 32 years. We supply other shops with import trannys but I like doing all kinds of street rod transmissions for alot of local guys, and we ship nationwide so if you're in the need I can help.
Redneckpsd
06-01-2008, 04:31 PM
Well I went ahead and bought the tranny I guess I will have to change the valve body. The real score was the geavendor bolted on the back.. will I need a trango reprogramer kit as well?
MarkB
06-02-2008, 06:14 AM
I wouldn't stress to much about the valve body change, just put a Transgo reprogramming kit in the valve body and change the governor to a gas governor, or just put lighter springs and weights on the governor and be done with it. Sounds like you did well if you gained a gear vendor. You should love the combination. Let us know if you need any help or any parts. Take care
Mark
