Bobby Schulz
05-29-2008, 06:42 AM
Hey guys new guy here with two 2nd gen camaros.
First is the one Im almost done with is a 1970-1/2 z/28 camaro im building to run in the pump gas drags. It has a dart tall deck AFR headed 598ci motor that is backed up with a little nitrous. It is a 10.2.1 compression 4.600 bore 4.500 stroke with with a pair of AFR magnum 345's ported/polished ,a solid roller cam with a 714 lift and a single carb 1095. Turbo 400 with a brake and 9 inch out back.
I run a 29x10 inch tire too.. no wheel tubs here guys:naughty: .
The 2nd is a 1972 RS/SS that will be a car to do a little of everything. Not sure if Im going to run a small block 355 I have built already from another project or if Im going to use the 454 block I have sitting ,stroke it and make a fuel injected 496:woot: The car will have either a 700R4 or a 6 speed, full interior with A/C, large x wide tires on all 4 sitting low to the ground ,and a aftermarket front subframe with all the goodies.
I plan to do a lot of small upgrades and some hidden/custom touches.
