View Full Version : Opinions wanted on Wheel adapters, are they safe?
1969CamaroRS
05-26-2008, 06:27 AM
I'm looking for opinions on wheel adaptors (not spacers). If they are safe / don't cause any vibrations or issues with changing the load on the suspension etc.
Example:
http://www.skulte.com/product_info.php/products_id/58
This would be 90% a street car (with occasional track use). The suspension / brakes are completely redone: GW uppers/lowers/coilovers/c5 brakes with AFX spindles, g-bar/mini-tub/12" discs in the rear and because of that I don't want to have to worry about breaking something either when I drive it hard (which I know I will do).
The reason I would need to run wheel adaptors in the first place is, I want to run the Wheel Vintiques Billet Rallyes (series 90) on my front C5 brakes from Touring classics. I know they won't clear. I haven't measured yet but I probably need a 3/4" to 1" adaptor to clear the caliper / brackets.
This would be the look I am going for (not my car 'shopped):
I am kind of going for that sleeper look and really just want to run the rallyes, I have looked at so many wheels that will fit the C5 brakes, but I still just want/love those rallyes :)
Thanks in advance!
bad bu 72
05-26-2008, 06:33 PM
i have used them for years on my 72 buick to fit zr1 wheels no problems at all
GBodyGMachine
05-27-2008, 07:53 AM
I run big spacers, have not had an issue yet.
O but do your self a BIG favor. Dont use the studs they provide. THEY SPIN in the spacers. I had it happen on both of my front spacers. Ended up putting in bigger and longer studs in the hub, and then just using the spacer w/o studs.
Jeff
BonzoHansen
05-27-2008, 08:27 AM
Man, that would suck - how would you get them off?
My only $0.02 is to hand retorque them every 100 miles or so for the first 500 miles - just like aluminum rims.
GBodyGMachine
05-27-2008, 12:13 PM
They luckily spun when the lug was about half way off the stud. I taped off the entire wheel and went after them with a cut off wheel. It was ugly and I was pissed.
muthstryker
05-27-2008, 03:07 PM
really? who did you go thru to have that problem??
GBodyGMachine
05-27-2008, 04:08 PM
eGay. Sorry for thread jacking
muthstryker
05-27-2008, 06:03 PM
Haha, wouldnt call it a thread jacking as you have helped everyone looking for wheel/adapters..
1969CamaroRS
05-27-2008, 07:19 PM
I agree as long as you helped the original person then a little banter doesn't hurt :)
DarkoNova
05-27-2008, 08:07 PM
I just got some adapters from Skulte. They're definitely quality pieces. I've got 1.25" for the front and 3/8" for the back, though I don't know if I'm going to use the rear ones. I could post some pics if you want, even though they look like the ones on Skulte's site. :razz:
Matt
ScotI
05-28-2008, 10:08 AM
I have 1" adapters from Skulte.
They've been on a daily driver since 2003 w/o any problems. The minimum thickness I would recommend is the 1" adapter. They offered a 7/8" one when I bought mine but getting lugnuts to work w/them was a major pain (hence the switch to 1" units). That being said, I don't think I would do any track time w/them. Use some different wheels w/sticky tires for your track days (they don't have to be pretty/bling wheels for the track).
1969CamaroRS
05-28-2008, 08:54 PM
ScotI thanks for the info.
I also heard about H&R adaptors being pretty good:
http://www.hrsprings.com/products/trak/
Mkelcy
05-29-2008, 05:04 AM
These people http://www.motorsport-tech.com/wheelAdapters can build anything you need.
ScotI
05-30-2008, 08:54 PM
The adapters I bought from Skulte were drop shipped from MST.
muthstryker
05-31-2008, 05:02 PM
I just purchased a set of adapters from motorsport tech, I will let you guys know how the quality is.
