View Full Version : Anyone know a good way to hook up kickdown for 700r4 to LS1?
CalSpeed
05-21-2008, 10:42 AM
Ive got this ls1 conversion almost completed and Ive got the same built 700r4 in the car. I need to hook up the kickdown to the throttle and havent thought of an easy way of doing it.
justanova
05-21-2008, 02:35 PM
http://www.tvmadeez.com/ls1_cam/
this is the only one ive seen, there may be others.
greygoose006
05-21-2008, 05:57 PM
700-r4 transmissions dont have a kickdown cable. they have a TV cable, and it must be set exactly or you will kill the trans.
i hope that is what you are talking about.
justasquid
05-21-2008, 10:29 PM
yeah, greygoos is right.
If not hooked up properly, it will kill the tranny fast. The TV cable needs to be set right or the trans wont build up enough pressure at the correct throttle inputs and you will smoke your clutches. If you've already driven the car without it adjusted, you could have already caused damage.
nx74ls6
05-22-2008, 11:50 AM
Call bowtie overdrives...they have adapters fro the LS1 TB.
GetMore
05-23-2008, 10:07 AM
As a matter of fact, I have one. It's on a Ram Jet manifold, but the throttle body is the same. It's a cool piece!
