View Full Version : First Gen. Camaro w/ Coil Overs in Front
Turbo67camaro
05-19-2008, 06:53 PM
Anyone using coil overs in the front of a 1st gen. Camaro, and very happy with their decision after driving thousands of miles ?
If so, which brand / model ?
I'm having a hard time choosing between using Coil Overs, or a spring and shock combo w/ either spring adjusters or spring shims to get the ride height dialed in.
Either way I go, I'm leaning towards adjustable shocks. Either solution allows for easy height adjustment. I suspect the latter solution will, dollar for dollar, handle slightly better. Granted, changing regular springs is a pain, but they should last longer than coil over springs. The shocks should die before springs, and the latter solution makes changing them easy.
