View Full Version : fender install (help me please)
67 ls1 vert
05-16-2008, 09:32 PM
Hi guys, I'm almost ready to install the front clip on my Camaro and I dont want to scratch up the inner fenders when I install the outside fenders. Do you guys install the inner fenders first or the outide fender first?
class67
05-16-2008, 10:10 PM
Bolt them together and install as one piece!
67 ls1 vert
05-16-2008, 10:31 PM
:hammer: Its that easy. LOL
Here I was making this harder than it needed to be. Do I leave the bolts a little loose and install them and then tighten everything up?
HOTRODSHOP
05-17-2008, 12:25 AM
yes,leave the bolts a little loose as you put the fenders on,then put in radiator cradle and line up fenders to doors and hang the hood and line up,,once evrything is lined up and tight to the cowl area and radiator support then tighten inner fender bolts and you may find they might still change how you are lined up and adjust them a little. also when lining up the front end have the wheels on and sitting on floor or jack stands under the suspension,not just under car somewhere.
