BRIAN
02-07-2005, 04:22 PM
I bought a set of DSE connectors thinking for some reason they would make my life easier but in the end wound up modifying them to the point that I just should have started with 2x3 tubing. The DSE stuff is 1st rate by the way for someone looking for direct weld in deal.
I welded rear section and bolted on front using 9/16's bolts and crush sleeves. Out of curiosity I hooked up my Snap On ball joint dial indicator and jacked up car from front crossmeber. This is bare shell and bare frame. The measurement is taken mtg the gauge from the front apron support and placing the indicator at the nearest portion of the rail near the body bushing. I also had Global West solid bushings. I am a little dissapointed to say the reading was approx .040. That is with only one bolt in each connector end as I was short 2 bolts. The problem after looking at the situation is the frame connectors even if welded to the subframe do not connect to any part of the body for about 12" back. Even if welded that is about 16" without touching the body for support. You can see the connector acually move down at the front when jacked up as the floor pan flexes. I plan on running roll bar tubing under seat brace connecting to connector to stop front flex.
Has anybody ever measured a stock rubber mtd no frame connector car this way? By the way I am assuming the measurement would be higher if taken from the front frame horn. I know the sheetmetal will stop most of this but I am just curious. I will post more accurate readings when I get the bolts and after I modify front of connector.
