View Full Version : Ford AOD
jp455
02-06-2005, 08:30 PM
Hi all. I was wondering, how tough is the ford AOD?
Also, what is the difference in feel between a lock-up and a non lock-up trans? Are non lock-up less fuel efficient?
Thanks!
manuel
It's not all that tough, but you can get them built for cheap. Non-lockup's are less fuel efficient, because it's basically like riding a clutch, and revving your motor more than need be all the time.
..all things said and done I'd go lockup.
airrj1
02-08-2005, 10:19 AM
Checkout http://www.lentechautomatics.com/
rancherlee
02-21-2005, 02:08 PM
Not very strong stock, but with about 800$ can take 500ft-lbs easy. Alot of the 4R70W parts bolt right into an AOD (its just an updated electronically controlled AOD with a wider gear ratio)
