View Full Version : *****help!!!****
lt1chevelle
04-30-2008, 09:30 PM
how do i get motor oil off paint!!!
newbaa
04-30-2008, 10:59 PM
wipe it off????? be a little more descriptive with your problem...
has it stained through the clear coat or something?
maybe try using a wax and grease remover or washing your car (not with dish soap).
Prep sol / WAX & GREASE REMOVER - What you use to clean a car just before you paint it !
Unless its stained it some how , Then , try Wet sand and rebuff !
lt1chevelle
05-01-2008, 07:58 PM
i have some of that, ill give it a try its not going to mess with the clear coat will it?
newbaa
05-02-2008, 09:04 PM
wax and grease remover? no, not at all. that's what we wiped our cars with down at school before we started doing any body work... it helps get rid of contaminants that you would otherwise be sanding right back into the work that you are doing.
so yeah, try the wax and grease remover. won't hurt anything and i'd be surprised if it doesn't work.
