View Full Version : Wilwood Proportion Valve
67w30
04-30-2008, 06:18 AM
When mounting a Wilwood Adj. Proportion Valve, does it have to be somewhere special or mounted in a certain positon? other than having the in and the out right? Does it have to be before the distrubiton block or can it be after? Do I have free rain' to mount anywhere I want? Even if close to the rear end, than close to the distrubition block or master cylinder?
Thanks Guys
Ken
Apogee
04-30-2008, 06:37 AM
You can mount an adjustable proportioning valve anywhere you like in the rear line, so long as it's before the rear tee fitting. A lot of the 4x4 truck guys mount them under their rig to the frame but that's just because it's easier to crawl under the rig to tweak the prop valve than it is to get into the engine compartment. The popular spot on most P/T builds is on or near the MC or sometimes through the firewall or floor near the driver so that it can be adjusted on the fly while driving.
Tobin
KORE3
67w30
04-30-2008, 07:13 AM
Thanks!!! I didn't want to put it in a convenient place and find out it would interfer.
Ken
