View Full Version : C6 front with LS1 rear... what master cylinder?
gearheads78
04-16-2008, 06:11 AM
I will be running manual brakes. Anything out there that will bolt to the stock studs in my 66? I would prefer something OEM to keep with the look in my engine compartment.
dhutton
04-16-2008, 06:24 AM
Most recommended master cylinder seems to be the 7/8" Wilwood but that doesn't look stock.
Don
Apogee
04-16-2008, 07:18 AM
You may look at the 1977 Malibu MC with manual disc/drum brakes...remove the residual pressure valve from the MC port for the rear brakes and you should be good to go. The MC has a 15/16" bore, deep pushrod hole and standard GM 3.40" hole spacing.
Tobin
KORE3
