View Full Version : what aluminum to use for intake plenum
ks71z28
04-15-2008, 06:14 PM
I am going to fab up a sheetmental plenum for my holley Stealth Ram intake, I was wondering what grade aluminum, it plan on using .90" thick sheet with 1/4" mounting flanges. It needs to be weldable and bendable
thanks
vp23271
04-15-2008, 08:53 PM
thanks
Did you mean 0.090" thick?
vp23271
04-16-2008, 08:32 AM
http://www.spectreperformance.com/#NEWS.NEWPRODUCTS.020607
The company above has a cold air intake for the Holley Stealth Ram. I don't like all the "connecting" elbows, but having a flexible joint between the throttle body and the intake tube might be a good idea.
I work in the aerospace industry and 6061 aluminum seems to be the norm for a lot of applications. The temper will determine how stiff or soft the material will be. Check out the link below. Hope the info helps.
http://www.metalreference.com/INFO_Aluminum1.html
ks71z28
04-16-2008, 10:38 AM
I am making the plenum, i already did the cold air intake.
.090" thick, sorry. It is a box that sits on top of a tunnel ram style intake. i want to increase volume and give it that "fab" look
vp23271
04-16-2008, 12:08 PM
Got it!
I thought the intake manifold and plenum were included together?
https://static1.pt-content.com/images/pt/2008/04/0307htp_holleystealth02_z-1.jpg
If you want to go with a custom fab look, you should check out Hogans for some ideas. They have some trick stuff!
http://www.hogansracingmanifolds.com/
