BulldawgMusclecars
04-14-2008, 11:42 PM
This tranmission is in my 97 Camaro SS, but I'm hoping someone here will have some ideas. For a little background, the car had a fairly new clutch and the slave was replaced within the last 20k miles. I was driving on the interstate, and it wouldn't downshift out of 6th...well, I eventually got it into 2nd, and got off the road. Before this, it shifted fine...no noise, no jumping out of gear, no hydraulic issues. I limped it how, took it apart, and didn't really see anything wrong. The hydraulics looked ok. Since I had it apart, and had a new McLeod disk and pressure plate, I put them in. No change. Someone on another forum suggested that a pin may have come loose inside the transmission (it had happened to the guy replying), but that doesn'tmake sense to me since I can shift into any gear, as long as the engine isn't running. Any ideas? I have a T56 rebuild manual and will tear into this thing if I have to, but I'm thinking maybe it is the hydraulics...even though they aren't leaking, and the fluid level is adequate. Could it by bypassing internally and not building pressure?
