    Results 1 to 14 of 14
      Oct 2006
      McKinney, TX
      dse tubs for first gen camaro
      ...I'm having difficulty figuring something out...
      I cut my rear frame rails about half way through at the ends. I've seen pictures of installs showing them cut almost 90% of the way through, and then some that are cut about 10% of the way through...
      Is there a "right" way?
      Mine are already in, so I have my fingers crossed that I cut to the right depth!!
      May 2002
      Northern California
      Some of the pictures might have had adjustment cuts for a bigger tire.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Mountain View, CA
      Sadly, there is a limited number of good photos of the process. People seem to be too busy doing it to stop and take photos.
      True T.
      My blog
      Bourbonnais, IL
      Just cut where the new tubs line up at?
      Auburn, WA
      Just follow the directions and cut. Don't worry about what the other guy did. Ours turned out great.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Dec 2007
      PA
      I am in the process of doing mine right now and will take pictures later this week and post them for you!
      Project 69 Camaro: Chassisworks G-Bar, FAB-9 & sub-frame, Fesler Billet, ISIS wiring & LS3!
      More pictures: http://camaro69vn10.com Updated!
      Used to be known as Camaro69vn10
      Kingsport, TN. 30 min. from Bristol and 90 min. from Pigeon Forge, TN.
      1/2" to 5/8" at its narrowest point seems to be the norm for most folks. Once you have the old inner wheelwell removed just keep slowly trimming the trunk floor and the frame rail. Insert the new tub after every trim trying the fit.
      Just be patient and make small cuts and trim a little each time. Do fit the new tub after each trim. Its easy to keep removing but gets a little more difficult to add back.
      Jul 2007
      Los Angeles, CA
      Quote Originally Posted by jpdeuce
      Pfft that is what the "metal stretcher" is for!
      Jun 2006
      if you get the install cd, then you can print out templates that you can apply to your frame rails. i did this on mine. they are very thin at one point !!
      Oct 2007
      Exactly what jpdeuce said.I test fit mine multiple times before i was happy with the fit.
      69 Nova
      427 small block
      [Mini tub pics]
      Nov 2007
      Yeah, I think the setback might vary a little from car to car depending on the exact distance of the frame rail to the outer lip of the quarter.
      Ron
      69 Camaro Redfire, thanks to
      Marquez Design | Ring Brothers
      Oct 2006
      McKinney, TX
      Mine are already in..I was just wondering because of this picture...it seems VERY THIN!!!!
      http://www.onelapcamaro.com/OLC_pics/booth%204%20b4.jpg
      I went out and checked...mine are about 3/4" thick at their thinnest point....
      Jul 2007
      Los Angeles, CA
      Quote Originally Posted by absintheisfun
      That does look scary. Check out this link from Steve N's site, where some reinforcements were made on the inboard side and underneath to reinforce the frame rails. I'm thinking of doing this as well when I get that far in my mini-tub:
      http://www.pbase.com/steven69/minitubs
      A bit more welding and fabrication but to me seems worth it for peace of mind, especially if the car will ever see the track.
      May 2002
      Northern California
      Don't let that picture scare you. Remember this car is running an L-D 3 link and is caged so it is quite strong. As I said before some guys will move that section in to provivde more tire room. 3/4" should be plenty for 335's.
      If it where running a leaf suspension I would recommend bracing on the inner part of the frame.
