View Full Version : Would this work??
Throttle
04-07-2008, 07:50 PM
If I where to Turbo a Big Block, would this FI work??
http://store.summitracing.com/partdetail.asp?part=acc-77106
I plan on using either a twin T-61 setup or a single T-76?? Well it be able to tune for turbo??
camcojb
04-08-2008, 06:35 AM
yes, but you'd need to upgrade the fuel pump and injectors for a turbo setup. Also swap the map sensor for a 2 or 3 bar depending on the boost level you wanted to run. The unit itself, manifold, throttle body, rails and ecu would be fine. You might talk to Frank at GP Superstore first, he may be able to do a package with the correct injectors and pump for less than buying them separately.
Jody
Throttle
04-08-2008, 10:51 AM
Thanks for the help.. Is he a member here??
I personally do not know much about FI systems.. They have a kit with 36pound injectors, how big do you think I need to go.. I wasnt planning on running a huge amount of boost, just enough to hit the 600hp mark with the highest psi I plan on running.. On the 2 or 3 bar map sensor, where can I get all that?? I can build old school, old tech stuff, but this FI stuff is over my head.. :(
I plan on learning about it through doing a FI system on my own car.. :D
Throttle
04-08-2008, 11:16 AM
I also planned on upgrading the pump from the one that came with the kit.. :D
ProdigyCustoms
04-08-2008, 12:12 PM
We are the GP SuperStore Jody recomended (Thanks Jody). Give me a call and we can discuss you project a bit and determine the best set up for you
four zero seven 832 1752
Throttle
04-08-2008, 03:46 PM
Thanks, I will give you a call..
camcojb
04-08-2008, 10:10 PM
yeah, sorry Frank, usually I leave a link, but was in a hurry.
Please call Frank, he will treat you very well, and knows all the ins and outs of what you want to do.
Jody
Throttle
04-28-2008, 05:46 PM
All right guys, I think I might be ready to actually start doing this project.. :evil
