View Full Version : SED Spindle
daryn67
02-03-2005, 08:24 AM
I've tried twice to e-mail Mark and both times my mail was returned. Does anyone know if they are still available and where i can get info and purchase these things?
Daryn
MoeBawlz
02-03-2005, 08:36 AM
I think that someone a while ago had talked to him about making another production run of them with using his design. I want to say it was ATS but im not positive on that.
MuscleRodz
02-03-2005, 09:33 AM
Tyler at ATS has them on his website, but I don't know if he has any stock on them. There are two versions, stock height and 1" taller.
ATS website (http://t56kit.com/)
Mike
68protouring454
02-03-2005, 11:25 AM
whats the deal with the sed spindle?? i remember hearing tyler had go ahead to produce them, but what advantages does it give you?? bigger front tire?? bigger wheel bearing?? someone let me know, i think steilow used them on his 67 red witch camaro that ran zr-1 vette wheels, with 315's out back
jake
nkopper
02-03-2005, 11:40 AM
The SED spindle was used on the Thrasher, not the Red Witch. The Red Witch used a 'vette spindle with modified factory control arms. I guess it didn't work that great. The original SED spindle is about 1" taller than stock, uses a C4 'Vette sealed bearing assembly, and allows 13" C4 'Vette style brakes to bolt up with no adapters. According to Mark's write up on the Thrasher in CHP (I think), the spindle allows for increased caster, a vastly improved camber curve, and neglible bump steer when set up properly. Tyler at ATS will be producing these in the near future.
Nathan
68protouring454
02-03-2005, 12:16 PM
thanks nate, they sound like a good deal, do you use factory uca/lca?? or any tubular ca?? i like the sealed bearing part and the better suspension gains, what will they go for??
jake
baz67
02-03-2005, 03:10 PM
Teetoe is working on getting the production prototype as we speak. You will not be disapointed for the wait. All I can say is there will be a 1" taller version and stock height. The better geometry comes from the better position of the UBJ.
Brian
nkopper
02-04-2005, 06:33 AM
They use factory uca/lca's. The C4 sealed bearings were around $200 each last time I checked. I think 93-97 camaro bearing assemblies will work too, but I have not verified that myself yet.
Nathan
TitoJones
02-05-2005, 01:34 PM
I don't know how I missed this thread, but yes ATS will be producing a modified version of the SED spindle.
The 1" taller version improves geometry over the stock setup by raising the upper ball joint. We also have a upper A arm relocation template for this spindle to give even better handling. It uses a sealed bearing assembly, and bolt on steering arm. Any upper and lower control arms can be used with this spindle.
The stock height spindle changes no geometry, so it can be used as an upgrade to a stock spindle, and use anyone manufacturer's geoemtry/arms.
This means if you have a DSE coil over conversion with a DSE tubular upper A arm, you can add this spindle with no ill effects on the designed geometry, yet still get a nice sealed bearing, a bunch of brake mounting options.
Both will be for sale in the very near future at www.t56kit.com (http://www.t56kit.com)
Let me know if there are any other questions on these.
Tyler
Steve68
02-10-2005, 04:44 AM
Tyler define "near future" I'm trying to do 13" brakes and not many people are making the adapter for the basket, and I was on this thread on the old board with you and a couple others, When will you be making them, and drum roll please, how much???? Thnks Steve
TitoJones
02-12-2005, 04:39 PM
By near furture, I mean Aprilish. Pricing is not completed at this time, so I won't even go there until I have a better understanding of how we are going to make them.
So far Shane and I have tossed around a forged aluminum version, a CNC stainless billet version, and a water-jet cut/Tig welded fabricated version, much like the orginal that Stielow built.
I'll have Shane post a pic.
Tyler
wickedmotorhead
02-12-2005, 08:31 PM
Per the boss' request here's a model of the current design. Obviously the design will change drastically for a forged or cast design. This is the fabricated design thus far. This spindle will undergo finite element analysis backed up by real world testing. Exact geometry results will follow as soon as the prototype is complete. Hope this helps.
Steve Chryssos
02-12-2005, 09:18 PM
Shane,
This is a PG rated website. You should take that upright picture down immediately.
TitoJones
02-12-2005, 09:59 PM
Car porn at it finest right there. We may need to add a 'Not Safe For Work' tag to the title of this thread.
Tyler
justanova
02-14-2005, 01:35 PM
me likey! The only concern for me I that I have been looking at circle trak rearends with the full floating hubs, but I can only get them with a 5 on 5 bolt circle, and I don't want to have to run diff bolt patterns front/back so with that in mind is there enough room on the corvette bearing/hub assembly to drill a 5" bolt circle on it without affecting the strength?
TitoJones
02-14-2005, 02:01 PM
Justnova-
I kinda doubt it. The hub doesn't leave much room for re-drilling.
Tyler
Steve68
02-15-2005, 05:04 AM
I looks like you guys have been working quite hard, Keep up the good work, and keep us posted, I know personally my car won't be finished by April, and changing out spindles really isn't that hard, Thanks for the info and pics, Steve
airrj1
02-15-2005, 07:17 AM
justanova,
Checkout: http://www.stockcarproducts.com/rear12e.htm I am not sure that this is what you are looking for, but it looks right. And it is on Sale right now.:attn:
02-15-2005, 09:10 AM
Check with Coleman Racing for hubs, if they don't offer them in the catalog, they can make a custom version for you.
