View Full Version : 69 camaro wheel fitment?
cakneller
02-02-2005, 03:10 PM
Opinions.........guidance...
I have a 69 camaro with stock discs in the front VWW 17x8 (4.5bs)
and 17x9.5 (5.5bs) rear wheels w/ stock drums on my car.
front 245/45 front 275/40 rear tires
the car has hotchkis front -2" and rear lowering springs.
Currently the rear rub on the inside fender well on a tight turn and
the front slightly rub on a fast turn on the upper inner fender well.
do you think by changing the brakes in the rear to disc that it will move the whelel out? anyone else have this problem?
in the front changing the disc to a c4 setup it will move it in slightly?
thanks,
chris
zman1969
02-02-2005, 04:27 PM
yes that will move it out about 1/4" due to the thickness of the rotor hub, there are also thin spacers available like factory iroc wheel spacers if you need more info let me know i have some avil if you need
good luck
