View Full Version : D1sc Accessory Drive Question
TnaGuy
03-26-2008, 10:02 PM
Hi all! Need some help on this one...anyone have BBC with Procharger and AC/PS/Alt drives? I am running the Mez high flow electric and 12 rib s-c drive belt. Need to know what options I have for this set-up.
Any help???
speedster
03-27-2008, 04:11 PM
You probably want to get a hold of Jody (camcojb here) because I think he had almost the exact same setup (made by SD Concept Engineering).
Frank at Prodigy Customs also is a whiz on Procharger setups.
67 caprice
03-27-2008, 06:06 PM
Any help??? I have all those accessories except my Meziere high flow is mechanical.
What are you trying to do?
speedster
03-27-2008, 06:31 PM
Is your setup carb or EFI?
67 caprice
03-27-2008, 06:33 PM
EFI
TnaGuy
03-29-2008, 06:28 PM
Thanx Speedster...I'll check with them both and see what they have to say.
I want to drive the accessories with the cleanest set-up possible, and the options seem limited from what I can find. The Elec WP makes it more complicated it seems...
I am going Carb, not FI.
Any other suggestions?
TnaGuy
03-30-2008, 12:44 PM
camcojb's set-up is diff, and Frank could not help at all. Any other ideas?
malihoochie
04-08-2008, 05:42 PM
Have you looked at March's brackets for the electric water pumps? They make a bracket for each of the main electric water pump brands. Hope that helps!
