View Full Version : Power Steering pump angle?
SicMonte
03-26-2008, 02:35 PM
I want to get this pump http://www.detroitspeed.com/productpages/indproduct/steeringprod/psp_aluminum_prod.htm
problem is, if I get it the pump it might be sitting at an angle when I install it. I have a remote resivoir type pump on there now with a Zoops mounting brackets and a turnbuckle tensioner. If I use my current set up with the DSE integral resivor pump, the pump opening (fill tube?) might not be straight up and down. It will most likelly be about 15-20 dgrees of camber. Would that affct anything??
MarkM66
03-27-2008, 06:02 AM
As long as the outlet tube isn't uncovered from fluid, I don't see why there would be a problem.
I'd just ask them when you order it.
