View Full Version : Where Did You Mount Your External Elec. Fuel Pump?
69TAPoser
03-26-2008, 01:27 PM
Looking for some pics to give me some ideas. I just installed a sumped Rick's tank and I need to figure out where to put my pump and how to route the line.
Phil
class67
03-26-2008, 05:40 PM
I mounted mine on the back side of the rear end hump and ran the lines down the right side underneath the car up to the regulator / gauge which is mounted below the heater core box kinda hidden) and then up to the carb from the back side of the engine.
https://static1.pt-content.com/images/pt/2008/03/PICT0006-1.jpg
https://static1.pt-content.com/images/pt/2008/03/PICT0005-1.jpg
69TAPoser
03-27-2008, 04:34 AM
Thanks for the pics Steve.:twothumbs
I ended up making a bracket that angles with the front angle in the trunk floor (from the bottom of the car). It puts the pump right between the gas tank and rearend with plenty of clearance. The only thing I wasn't crazy about was drilling 4 holes in my new trunk pan.
Phil
