    Results 1 to 20 of 23
      Oct 2007
      Lubbock, TX
      How do I install door panels?
      I bought a pair of aluminum door panels for my interior and I was curious how would I go with installing them? I want a clean look like with rivets but I would be screwed if I ever need to pull them off to repair a window or something. Any ideas experts?
      Phoenix, AZ
      Do a zerc fitting in the door with a nice button head bolt in the panel, they will be clean and can be taken off at anytime...... This will look the best and be easy to do.
      Chris Fesler
      Dec 2007
      Gilroy, CA
      what kind of door panels did you buy?
      1969 Chevelle
      www.creationsultd.com
      OC CA
      Got any pics?
      Mark
      LS1- T56
      under construction
      "Political Correctness is a doctrine, fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
      Oct 2007
      Lubbock, TX
      no sorry, no pics. I'm going to the storage tommorow and I can take some then.
      Whats a zerc fitting? I never heard of that.
      OC CA
      Quote Originally Posted by West Texas Z
      Maybe so you can lube up your door panels LOL
      I think he meant to say Dzuz fasteners: http://www.jegs.com/p/Moroso/748742/10002/-1/11333
      Mark
      LS1- T56
      under construction
      Oct 2007
      Lubbock, TX
      ah! gotcha. That would look better that some plain nuts and bolts. Thanks. ^
      Nov 2004
      Sweden
      Country Flag: Sweden
      "POP NUTS" (pics.)
      Check this out !
      http://www.emhart.com/products/pop/popnut.asp
      I used "Pop Nuts" when I made this box for the fuelcell tank.
      Easy to take apart.(see pics)
      I´m sure You can use them for the door panels.
      http://www.google.se/search?q=pop+nu...-8&sa=N&tab=iw
      Oct 2007
      Lubbock, TX
      Woah osdmike!!! Thats perfect. Are they expensive? I need to buy the tool gun too huh?
      Central Florida
      You can get them in kit form by Marson. Most of your local supply shops like Fastenal carry them or can get them.
      Make sure you get the rivet nut style...it's knurled and helps to hold it in place.
      Here is a link:
      http://www.blindrivetsupply.com/detail.aspx?ID=784
      Oct 2007
      Lubbock, TX
      thanks for the links. I'll look into that. =)
      san diego
      any updates and pictures?
      Rockford Illinois
      I am not sure what look you are looking for but here is a pic of my aluminum door panel done with perforated aluminum. I just used black trim screws that I picked up at fastenal, they are the Aweveco brand that they carry. Just a simple screw in black oxide.I used rubber edging that I picked up from Mcmaster-Carr to finish it off.
      Hope this helps you. The rivnuts are nice and I have them but decided it was not neccessary and in a few places not quite workable do to the job because of the angles.
      san diego
      thanks Jim,
      Im thinking about .100" aluminum and cutouts in the Al with tweed inserts.
      Rockford Illinois
      Quote Originally Posted by falcon65 View Post
      thanks Jim,
      If you go with 6061 you could go down to .060 and still be more than stiff enough and cut off some more weight if it is any concern.
      Sounds like it will be really nice with the tweed inserts, can't wait to see it done.
      san diego
      i am going to use .100 so i can round the edges for a more finished look. Weight is a huge concern of mine. The car only weighs 2690 right now.
      Rockford Illinois
      You can get an aluminum edging that will do the same thing the rubber edging I used does.As long as the radius's of the panel will allow it you can do it without wrinkling it. The inserts you plan on doing may reduce the weight and the extra thickness might be needed to keep it stiff where they are, you could also do both if needed.
      I am liking the weight of your car and am curious as to how far you are on the build so far? I was at 2650 and thought I only had another 200 to go and ended up at 3150 so far. I couldn't believe I was that far off in the end. It all adds up so quickly.
      Are you going to leave the aluminum natural or paint and what color is the tweed going to be?
      Keep us posted.
      san diego
      Jim check out my build thread.
      https://www.pro-touring.com/forum/sh...ad.php?t=58842
      My car is complete with all parts on it. I am currently driving it. More modifications to come.
      The theme of my car is satin aluminum, so teh door panels will be satin, they will match my dash and steering column and steering wheel as well as the engine compartment.
      Rockford Illinois
      Nice ,very nice. The engineering concepts are right on track to the way I think I can't believe it.
      I remember the days when I was full fledged Ford guy and had many thoughts of lightweight Falcons. You have to make the Blue oval guys more than proud.
      Someday somewhere I hope we meet.
      san diego
      Wow Jim. that means a lot coming from you.
      I will be at SEMA this year, If you make it over this way.
