View Full Version : Gbar and exhaust compatibility
Dr.Corvette
03-11-2008, 06:25 PM
My 67 Firebird has a Pypes crossflow muffler system. Will this work with a Gbar? If not who makes a compatible exhaust?
ProdigyCustoms
03-11-2008, 07:06 PM
We sell and install a lot of G Bars. No the cross flow will not work and no one makes a out of the box tailpipe kit that fits a G Bar set up. Stainless works has "wheel barrow handle tailpipes" only in 2 1/2" that go under the rear, but are not to attractive by their own admission. You will have to get a shop to bend up tailpipes or weld up mandrel bends. However, you can get up to 3" exhaust through. As for ready made tailpipes, I doubt anyone can do them in mandrel bend due to turn radius. Notching the corners of the fuel tank will help a bunch snaking tailpipes through.
darren@ridetech
03-12-2008, 06:25 AM
Rick's just built us a tank for the back of our 68 with the corners already notched.
ProdigyCustoms
03-12-2008, 07:21 AM
Darren, are you going over the axle on this one? The Rick's tank is the one we sell, works killer.
bret
03-12-2008, 10:07 AM
On Sharon's 67 Camaro [and her replacement 68] we went under the rear axle. I know this sounds hokey in theory, but in reality the rearend sits so far up in the car with the AirBar that it is a straight shot from the mufflers, then under the rearend and then up around the gas tank. A tank with mitered corners is nearly a must if you are using the DSE minitubs. With stock tubs the stock tank works fine.
whytry
03-12-2008, 12:01 PM
Got any pics of that Bret? I am looking at the Airbar, and I really don't want turn downs, and I want the car low when aired out.
jb@ridetech
03-12-2008, 12:24 PM
here are a few from the (old camaro) we dont have the exhaust done on the orange one.
nicks67camaro
03-12-2008, 12:27 PM
I also went under the axle. I did a one exhause that doesn't use a gasket It drops our as one piece from the collector back. Its a 3 inch round x and then to a 3 inch oval and 3 inch oval tail pipes. I have tons of clearance compared to the 3 inch flowmasters I had. I want to change out the x to an oval when I got more cash. all spintech stuff really nice.
whytry
03-13-2008, 08:43 AM
Thanks Bret. I am currently running the Flowmaster tailpipe kit on my leaf springs setup, but I was hoping to be able to keep tailpipes when I go to Airbar. Those pics help make the decision a lot easier!!
dhutton
03-14-2008, 07:28 AM
What clearance do you have between the axle and the pipes where you go under? It's hard to tell in the pictures.
Don
whytry
03-14-2008, 08:44 AM
When it was airred all the way out did the exhaust hit the floorboards? Do you have any old pics of it airred out? I used to have some saved on my computer but I can't find them
ProdigyCustoms
03-14-2008, 06:54 PM
Don, BTW, Stainless Works goes under the rear and only in 2 1/2"
darren@ridetech
03-17-2008, 07:25 AM
The exhaust doesn't move with the suspension. Here is an image of the car deflated.
http://www.ridetech.com/gallery/browseimages.php?c=20
As soon as we get the exhaust done, I'll post up some pics.
Now, when we did the exhaust on our 70 Nova we ran it over the axle. I think that it was 2 1/2 tho. The AirBar is virtually identical compared to the Camaro.
darren@ridetech
03-17-2008, 07:26 AM
Don
I don't have any good pics, but with the suspension fully extended it was pretty close. I would go look, but the car was stolen last year so I can't.
