View Full Version : Opinions on a Carb
01somta
03-10-2008, 05:20 PM
This is mainly going to be a street/show car, it may see the 1/4 mile twice a year or so. What carb. do you think would be compliment my setup? I am open to all opinions. Here is my setup;
502 Gen VI 4 bolt main, 9:1 CR
Melling hv oil pump
Crane solid roller p/n 168601 cam .615 .636 246 254 dur @ .050,
crane solid roller lifters
GMPP 12363400 Aluminum Rectangle port heads
GMPP 12361323 1.7 alum Rockers
Edelbrock victor jr 454-R intake
Crank Ext. ballanced, nitriated, crossed drilled gm p/n 10198922
Rods Forged 4340 Steel
Pistons GM P/N 12533507 Forged Aluminum
MSD Pro-Billet Dist.
Shaker455
03-11-2008, 12:33 PM
A custom built Holley 850 made from select parts and calabrated to your combo would serve you best.
I build them that way, live tested and advise thru final tuning.
You will never get that kind of service from an off the shelf model.
01somta
03-11-2008, 07:19 PM
The car will have a tko600 and mainly street driven, would mechanical secondaries be the way to go?
Shaker455
03-12-2008, 12:07 PM
Yes
72BBNova
03-12-2008, 03:36 PM
I would give Sean Murphy a call at SMI Induction. With your set up I bet he would recommend his stage 3 850 cfm mech secondaries. It wet flows at 920 cfm. The cam that you have is very close to the one that I'm going with for my 468, with a TKO600 and that's the one that he recommended. Here's a link to his web site. Sean builds a great carb and is a master on the Q-jet. http://www.smicarburetor.com/products/?sfID1=28&sfID2=5&productID=43
01somta
03-12-2008, 06:06 PM
I just looked at the carb that came with the motor, the list number is 4781-3 and 2330 under the list number. I have been looking for another carb b/c the previous owner of the motor said it smoked a little bit at start up with this carb., and the smoking cleared up with other carbs. Would it be better to just send it off to get rebuilt for my car?
Shaker455
03-12-2008, 07:37 PM
Sure and I provide that service.
Typically the 850 have a overly rich idle circuit and display poor A/F @ part throttle cruise.
There's many mods I do that can improve it's performance
Email or PM me
01somta
03-13-2008, 12:55 PM
pm sent
Shaker455
03-13-2008, 03:02 PM
PM responded to.
01somta
03-13-2008, 05:52 PM
email sent
