View Full Version : Ignition Connector / Fuse Block / Need More Terminals
bigboi
03-09-2008, 06:38 PM
I have a question... It seems like I have been wiring a bunch of things to my Fuse Block IGN. Isn't there a small piece that allows for more terminal connections on the Fuse Block? It's like a brass piece that plugs into the IGN terminal and it splits into 3 different terminals.
Does anyone know where I can get this from? I am sure someone knows where. I checked the local parts stores and couldn't find anything.
Thanks!
oestek
03-10-2008, 06:25 AM
If you find yourself wiring lots of stuff to that terminal, you may want to consider wiring in a separate terminal that is connected to the IGN circuit. MAD enterprises sells them for less than $10, it's actually a GM part number but dealers always look at you funny when you describe it.
http://www.madelectrical.com/catalog/cn-1.shtml
This will allow you to keep the fuse box clean and add much more to the system without taxing the IGN terminal.
