View Full Version : Measuring for wheels/tires
86Cutlass383SR
03-02-2008, 08:40 AM
On a daily driven street car, what is the minimum clearance between the inner wheelhousing/frame and the tire. In my case, the 86 Cutlass, the frame is the closest point of tire contact. Would you say 3/8" clearance is enough or 1/2"? More? I don't feel easy running any less than 3/8".
I have some tires I'm mocking into place and want to measure for my wheel backspacing.
Doug
jackfrost
03-03-2008, 09:00 AM
notch it. :evil:
i spent a couple hours cutting on my frame this weekend. it's fun.
Tony_SS
03-03-2008, 01:23 PM
No less that 3/8" is where I would set it. I'm right at 3/8" clearance now on the inner frame.
03-03-2008, 01:46 PM
You can get closer with a link suspension depending on your locating device. Also tire/rim sizes. ie you can gain more clearence with a 40 series on an 17"+ than a 60 series on a 15" due to tire bulge and sidewall flex.
Hey Tony, you get any rub going into a driveway or hard turning? I'd call 3/8" a minimum.
Tony_SS
03-04-2008, 07:01 AM
Sure don't and those were on 275/50-17's. Those have been replaced with 285/40-17's so even though the clearance is still 3/8", there should be less flex with the tire so rubbing still shouldn't be an issue.
86Cutlass383SR
03-04-2008, 05:55 PM
I appreciate the replies. I do plan on running a 275/40/17 tire on a 9" wheel. I had thought about notching the frame but then I'd be trying to go even bigger...LOL.
I plan on using aftermarket upper and lower control arms with some type of GW - type bushings and/or spherical setup. I also plan on replacing my worn out body mounts with the poly mounts and squaring up the body/frame side - to - side measurements.
Tony, what are you running on your backspacing?
I need my limits or things can get outta hand...faster than they normally do!!!
Doug
Tony_SS
03-04-2008, 07:04 PM
4.5 bs on the rears. And that's on a 9.5" wheel. The Nitto 555 runs a tad small so I went with a 285/40 to get a 26" tall tire back there.
I'm real happy with the fit, its basically flush with the unrolled inner lip.
86Cutlass383SR
03-04-2008, 07:50 PM
I think that's about what I measured out on my Cutlass. I'm going to replace my body mounts and get the body even on both sides before I re-measure and order my wheels just to make sure.
Doug
