View Full Version : Brake Lines???
jy211
02-28-2008, 08:46 AM
As I sit here waiting for my wilwood order to arrive (4 wheel kit)...I think about the brake lines for my 55' chevy project...Do I just order stainless OEM style or do I just make my own....
Pro's - lines come pre bent ready to install
Con's - Can't use an aftermarket company that sells colored tubes
Suggestions?
redhead
02-28-2008, 09:44 AM
I was following your logic until you mixed the anodized word with stainless.
anyway, if the 55 had stock discs than a prebent kit might apply but in your case how do you know a generic prebent system will work for your aftermarket setup? personally I think it is a leap of faith for you to believe that a prefab will work out.
if you have time and are not intimidated by the job, do it yourself.
da.
jy211
02-28-2008, 10:17 AM
Thanks...What I meant was using something like these: www.protubeonline.com (http://www.protubeonline.com) in a color...should not have used the word anodozed...
I was thinking of using all black so the lines wouldn't be seen easily...
