View Full Version : Weld pro stars and C5 brakes?
CamaroJesse
02-25-2008, 04:33 PM
Im just wondering if weld prostar skinnies will fit on c5 brakes. i had them on my old 98 trans am but i needed a 1/4 inch spacer. This may be the same thing.
thanks
Jesse
James OLC
02-25-2008, 07:50 PM
I had 4" Prostars on my last '67 with Baer PBR's. I had to grind the outer edge of the calipers to clear the inside of the wheels. If i recall correctly, I think that I could have gotten away with an 1/8" spacer but I don't like running spacers so out came the die grinder. I would assume that clearances would be the same with stock C5 brakes/
Apogee
02-26-2008, 08:57 AM
The 98 F-body had 12" rotors, not 12.8" like the C5 setup, so I would think the interference issues would be exacerbated somewhat.
James, what Baer PBR calipers were you running? GT = C5...otherwise if it was a track kit (C4), then the calipers are much smaller and would more than likely present much less of a fitment issue.
Feel free to download fitment templates from our website if you like, that's what they're there for. http://www.kore3.com/tech.php#fitment_templates
Tobin
KORE3
