View Full Version : In Stock-3pc splined rear sway bar for DSE Quadralink
TitoJones
02-21-2008, 11:44 AM
Guys-
We have custom made rear splined sway bars for use with the DSE Quadralink in stock. We took the lessons learned from Mark Stielows Mule and Camaro X and had this bar made up to match his specs. The bar is a solid 3/4" with corvette end links and aluminum arms. the arms must be cut to length, and then drilled and tapped for attachment.
Pricing is $350 shipped.
Tyler
zbugger
02-21-2008, 04:15 PM
Tyler, where/how does it attach to the axle? Would this be adaptable to a stock type leaf spring suspension?
TitoJones
02-22-2008, 10:24 AM
The pillow blocks attach to the axle right on the DSE brackets. The end links need to be attached to the body and the arms need to be cut to length and then tapped.
https://static1.pt-content.com/images/pt/2008/02/0021-1.jpg
Tyler
TMat
02-22-2008, 11:05 AM
Any chance of a splined front sway bar coming out for stock subframes?
6'9"Witha69
02-22-2008, 11:52 AM
They have one as part of the Chicane LM setup. Don't know if it is available seperately though.
Rick Dorion
03-19-2008, 03:46 AM
Tyler, any plans for a version for a stock leaf rear setup?
