View Full Version : Looking for a 5" tall 1350 or 1330 9" yoke
funcars
02-19-2008, 08:32 PM
I've been calling all over the country to find a tall yoke (5 in long) to fit a 9" with a Daytona pinion support. I have a brand new 4" OD driveshaft with 1350 U-joints, but it's about 1 inch too short. A taller pinion yoke would solve my problem. I could run a 1350 or a 1330 (with a conversion u-joint). So far the only thing I've found close is a used tall 3R yoke. I've tried Strange, MW, Moser, Currie, etc. Anyone know a place I should try?
chicane67
02-19-2008, 09:27 PM
The only yoke longer than 3 7/8" (end to U-joint CL) is going to be an OEM tall yoke. No one makes the taller yokes... that is affordable anyway.
Mark Williams (http://www.markwilliams.com/Catalog/pg70.pdf) doesnt even make one... and they make everything.
Check your PM. I sent you two contacts that may have a tall yoke for a DPS on the shelf.
chicane67
02-19-2008, 11:10 PM
Tex Racing has one available... P/N TRE2321
No idea on price, but they make a billet unit.
funcars
02-20-2008, 02:21 PM
Unfortunately the Tex racing part is only 4 inches tall too. There is a 1330 truck yoke available in a 5" height that should work. I'll make sure to get a good u-joint.
