View Full Version : Where to get intake tubing?
Kokamo
02-18-2008, 06:23 PM
Hey guys, great site. I could be reading here for the rest of my life and not be done.
Anyway, I have an LS1 in my 69 Camaro and I need to come up with some sort of intake piping from the throttle body to go thru the right side of the radiator support and then put a filter on it. So basically I need one 90* from the throttle body, then I put my air flow sensor on that, then a strait peice of pipe, then a 90* pipe to go forward to the radiator support, then prolly another 90 or 45 to put the air filter onto.
I would like to use plastic since it's cheaper, but I guess I'll settle for aluminum.
Any ideas of where to get this stuff?
Joe
Samckitt
02-18-2008, 06:32 PM
Search ebay for: aluminum tubing 3
Or check auction 330211680562.
That is what I used.
joeljet
02-19-2008, 07:52 AM
heres one place http://intakehoses.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=I&Category_Code=HC7
70LS1NOVA
02-19-2008, 07:59 AM
I bought my 90* elbow at pepboys but I found the tubing at http://www.boostcontroller.com/index.php?category=130
redfire69
02-19-2008, 08:03 AM
Spectre's got some nice 4" stuff. I used in on my carb'ed TA.
http://www.jegs.com/p/Spectre/769283/10002/-1/10269
Iamtheonlyreal1
02-19-2008, 08:48 AM
Here is my design from Spectre...You can order there Mock up kit before you go through the expense of purchasing and returning different peices.. The front view is not centered yet, but it does clear the condenser.
Kokamo
02-19-2008, 12:37 PM
Rob, very nice man. Looks great! I had ideas of doing exactly what you have done, but I remembered about the upper radiator hose. It looks like your will clear since it's slightly lower.
PM sent,
Joe
78_elky
02-19-2008, 01:03 PM
I used the spectre stuff on my el camino with their carb bonnet. and it worked pretty good
-Josh
Iamtheonlyreal1
02-19-2008, 01:32 PM
Yeah everything clears quite well...It is a quality kit
jkwalkercchs
02-23-2008, 02:50 AM
if u have an exhaust shop around that does mandrel bends a couple of us truck guys have used that method
quadfather
02-23-2008, 10:54 AM
try this place www.globaltecheng.com/alutubing.htm? the best source i hace found for alum tubing great prices.
xssive99
03-09-2008, 05:41 PM
Global Tech is about the cheapest you will find and they are quick!
