View Full Version : unisteer power rack
tony hernandez
02-18-2008, 03:28 AM
hello
has any one used a unisteer power r/p system from unisteer?
i have a 69 rs/ss with the factory power steering set up i was going to change over to unisteer system, any advice on doing this?
i have header clearence problem with my small block.
is the steering geomitary the same as the factory one.
i need heads up please.
thank you
tony
zbugger
02-18-2008, 01:23 PM
The geometry is improved for bump steer. They supply new steering arms to help with this, as well as the rack being custom for the car. The feel is pretty good. What clearance problems to you have? Just with the steering box?
tony hernandez
02-18-2008, 06:25 PM
yes the steering box does not clear the headers that i have.
have u tried one of these set-up's from unisteer?
i ordered a new set of headers from hooker to see if it will clear.
i also wanted to get a better feel from the steering. will this set-up do it?
thanks
tony
Sir Don
02-20-2008, 08:33 AM
I have a 69 also, but the car is not back on the road yet. Went onto the subframe fine, as long as I followed directions. The two bolts are at an angle, so the one side needs to be mounted and the unit against the subframe for it to be over enough to get the second bolt through.
tony hernandez
02-21-2008, 01:06 AM
ok thanks for the info ! any heads up on the diffrence between a steering box veres a power rack and pinon set up ?
tony
