Results 1 to 15 of 15
02-17-2008 #1
- Join Date
- Nov 2007
- Posts
- 266
trans tunnel sheet metal chevelle
hey, Today I pulled the carpet on the chevelle and sadly the guy that had it before decided to totally destroy the tunnel installing a manual in it. He riveted aluminum over the gapping hole and sprayed undercoating over it disguising it from the bottom. So regardless of what he did I need to repair it. I looked at OPGI and Year One and I didnt see a trans tunnel repair piece, only half pans that I would end up needing to buy two cause they are split down the middle. I considered that bone yard in Arizona that was mentioned on V8tv (cant remember the name at the moment) and just get a tunnel cut for me but I think that would be a second choice considering that I need to prep it to get it cleaned up which obviously takes time and time is my enemy cause I lack it. If you can shoot me in the direction of a repair panel that fixes the tunnel over the top of the shifter area please send me in that direction, otherwise Ill get a cut one and use that. Thanks
02-17-2008 #2Is this what you need?
http://www.opgi.com/product.asp?topc...074&yearrange=The needs of the many outweigh the needs of the few.
02-17-2008 #3
- Join Date
- Nov 2007
- Posts
- 266
no sadly, the car was originally a column shift auto car. Previous owner cut roughly half of the trans tunnel out for the shifter when he converted it to a 4 speed(he took out WAY more than necessary). What I need is the tunnel for a column shift car cause I plan on running a 4l65e with a cable shifter. Unfortunately I didnt take a pic today or else Id post it and I probably will tomorrow but what I need i a panel that would cover from the part where the tunnel turns into the drive shaft tunnel and up to the seam where the firewall portion of the tunnel mates to the itermediate portion of the trans tunnel. Hope that makes sense but if you were to look at it, the tunnel is made of three pieces.. one is very wide at the front, then a seam and the middle portion of the tunnel and lastly the driveshaft prtion and I need the middle.
ok found a pic of a floor pan and I outlined the area i need but without a shifter hole
1964 Malibu GT1 TWIN TURBO GEN 3 THREE LINK REAR
02-18-2008 #4Just make one from sheetmetal
Thall shall fear no amount of boost, For thy bottle is with me.......
02-18-2008 #5That was going to be my next suggestion.
02-18-2008 #6Unless you are doing a resto, seems like alot of work to replace all the way to the f/wall. Why not just do a "proper" patch and put the carpet back in? I'm sure finding a donor section used won't be too hard. Even one with a shifter hole wouldn't be too tough to close up.
JMHO, MarkMark
LS1- T56
under construction
"Political Correctness is a doctrine, fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
02-18-2008 #7
- Join Date
- Nov 2007
- Posts
- 266
The hole I have to fix is huge and I dont have a sheetmetal roller to do the tunnel so sounds like Ill be getting a donor panel
02-18-2008 #8If you have a leg, you have a sheet metal bender.
Or, a heavy gauge piece of stove pipe. They're usually not crimped together in the store, and they're already curved.The needs of the many outweigh the needs of the few.
02-18-2008 #9
- Join Date
- Nov 2007
- Posts
- 266
nah I prefer the right way since I have options and I should have my cut from desert valley auto parts shortly
02-18-2008 #10
