    Results 1 to 5 of 5
      CT
      DSE Mini Tub question
      I am installing a DSE mini tub kit in my 69 Camaro and it looks like you could use a factory fuel tank?? Is it the leaf springs that make you have to use a custom tank??
      Dec 2007
      Pittsburgh, PA
      The leaf springs don't change when you install the mini tubs. You can still use the stock tank. The only other thing that changes is the location of your shocks.
      Mark
      70 Nova, Hotchkis springs and sway bar GW uppers, Bilsteins, , sub connectors, Smooth firewall hidden wiper motor, LS1, 425 rwhp, 175 NOS Ridetech 4 link HQ Coilovers, Mini tubs, 315's. Ridetech billet gas cap, FLT level 5 4L60E, Yank
      NY
      Yes. If you use the offset shackles, you would need a custom tank.
      The needs of the many outweigh the needs of the few.
      CT
      Do you have to use the offset shackles??
      Apr 2004
      OKC, OK
      If you want to run wider than stock tires, the reason for the minitub, you have to run offset shackles for the leafs to clear the tires. When you move the leafs, then you have to narrow the gas tank. If you run a quadralink, you might get away with a stock tank width.
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
