View Full Version : roll bar in a full frame car
large
02-04-2008, 06:09 PM
I have a 1966 chevelle that I am going to install a 8 point S&W cage how should I mount it to floor plates or to the frame and if to the frame how would you do it I am concerned about being able to remove the body later it is a frame off rebuild mostly for the street ?
Scott Norris
02-04-2008, 06:37 PM
plates top and bottom of sheetmetal bolt plates together weld bottom plate to frame.
large
02-05-2008, 01:07 PM
thanks for the response I had thought about that but what should I do for body mounts thanks
jn6047
05-11-2008, 02:19 AM
Any thoughts on what is best for a pick-up with a full frame and an 8 point cage that will be used mostly for the street but occasionaly for the drag strip?
I've been thinking of a few different options:
-cage welded to frame outriggers, body mounted with rubber
-frame bolted/sandwiched with outriggers and the body mounted with solid mounts
-cage welded to both the frame and body, and the body mounted with solid mounts
-body and cage welded solid to frame with custom floor pans
-cage welded to the body, body bolted to the frame
thanks
jn6047
05-11-2008, 03:19 AM
Also, anyone know what the NHRA rules state as far as roll cage mounting? I've read a few different things, and I'm uncertain what the final say is. Thanks again.
jn6047
05-11-2008, 12:13 PM
To clarify, if I were to weld the roll cage plates to the area where my factory body mounts bolts go through, will that abide by NHRA rules?
jn6047
jerome
05-12-2008, 08:16 AM
I'm planning on doing something like this:
http://www.polyperformance.com/shop/product.php?productid=433&cat=551&page=1#tabs
This is for an S10 by the way.
