View Full Version : size of wheel stud bore press fit
night_rider_692004
02-03-2008, 06:17 AM
Hello!
I want to install new wheel studs because of a brake conversion. Now I noticed that my new press fit studs have a bigger diameter of the "knurling". So it's not possible to press in without drilling. But what is the right bore size for a press fit?
The new studs have approx 13 mm (0,51 inch) od at the knurling.
Apogee
02-03-2008, 08:51 AM
Do you know what the stud part number is (Dorman for example would be 610-XXX)? That would allow us to look up a more accurate knurl diameter for the wheel stud in question. Typically .005"-.009" interference is sufficient for most wheel studs into steel.
Tobin
KORE3
night_rider_692004
02-03-2008, 10:45 AM
Hello!
Part No is MOROSO 46160
I think I have to drill 0,552".....I found the parts on moroso homepage.
Do you agree with this size? I don't have any experience with press fit wheel studs.
Apogee
02-03-2008, 01:22 PM
Yes, a .552" ream [14mm] would be perfect for the 46160 Moroso studs.
Tobin
KORE3
