View Full Version : 18 front 19 rear combo ?
radback
02-01-2008, 11:26 PM
Hi there,
Do you know some affordable wheels available in 18 and 19?
I wanted to go Smoothie II: no 19
same for Torque Thrust.
Which wheels available in 19 in the same style and same price range than Smoothie II?
Boesch
02-02-2008, 07:02 AM
What's your definition of "affordable" ? Posting a price range will get you more responses.
class67
02-02-2008, 08:27 AM
I'd say he's looking in the TTII price range!!! no offense, but good luck.
Apogee
02-02-2008, 08:49 AM
Short answer, no, unless you can find a set used somewhere. I picked up a set of used C6 18x8.5 and 19x10 5-spoke wheels for $275...but then had to machine custom wheel adapters to give me the offset I needed. It still ended up being significantly cheaper than any other route, but it's not exactly the TTII or Smoothie look you seem to be going for either.
Tobin
KORE3
DriverzInc
02-02-2008, 12:54 PM
I'm going to have to agree with Apogee. You will be into two piece billet pricing. For Example, our 19" Rushforth Wheels are 662.50ea.
radback
02-02-2008, 02:58 PM
So, no cast wheels in 19"?
My budget is about $1500 max for 4 rims (I will buy tires locally).
So I suppose I must decide to go 18/18 or 18/20...
I want 27" tire front, and 28 or 29 rear.
Any pics of second gen with 18/20?
35spline
02-02-2008, 07:33 PM
How about some after market BMW wheels? I got two new 18X8.5" and two 19X9.5" Stern Wheels from Unlimited Automobile Products delivered to my door (all four of them) for $650. I am currently getting the 19" rears widened to 12.5" so no pics with tires yet. Here is a pic without tires. https://static1.pt-content.com/images/noimg.gif
68Formula
02-03-2008, 12:22 AM
Wow I thought I had a screaming deal when I bought my 17s for $500 plus shipping. How can they do that? Thanks for the tip. Wish you were here 4 years ago.
radback
02-03-2008, 04:33 AM
Well, it's not exactly the same bolt patern.
I don't feel it's safe to run them at +100mph.
35spline
02-03-2008, 08:26 AM
Search the board for others who have successfully run the BMW wheels that have a 120mm bolt pattern. In most cases an inexpensive set of hub-centric rings will center the wheel on the hub. The actual difference between a 4.75 bolt pattern and a 120mm pattern is 0.026" and remember that difference is spread across the whole bolt pattern. If you measure that on a caliper you will realize just how small of a difference this is, less than this !!
BTW in most cases traveling at 100 mph is not going to be safe.
radback
02-03-2008, 10:18 AM
I'm in France.
Here, legal speed limit on highway is 80mph, and many people drive at 100mph (lot less now because of speed traps). And Germany is near, and they don't have speed limits :) .
100mph is not a dangerous speed on an empty highway, except if your wheels got some movement because bad fitting or unbalance...
PS: I not usually drive fast, but I want to be able to do so sometime.
Tony_SS
02-03-2008, 10:35 AM
I think those wheels look really nice, but for a 9.5 wheel, the lip looks pretty shallow. I assume you are running a thick spacer with those?
Can't beat the price though! But you have to figure in the cost of a set of spacers as well... ($200+)?
35spline
02-03-2008, 11:46 AM
The Camaro has been tubbed so no spacers required in the rear.
radback
02-06-2008, 08:51 PM
So, except expensive billet wheels, no 19 available?
Autodetalles
07-06-2010, 12:56 AM
Here 18inch Mille Miglia Evo, for BMWs:postpics::postpics:
